Saltar al contenido principal
LG G5 Battery Replacement
Qué necesitas
  1. LG G5 Battery Replacement, Battery: paso 1, imagen 1 de 3 LG G5 Battery Replacement, Battery: paso 1, imagen 2 de 3 LG G5 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: paso 2, imagen 1 de 2 LG G5 Battery Replacement: paso 2, imagen 2 de 2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
Conclusión
21 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,786 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,818 Guías creadas
4 comentarios
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Contestar
Was machen wenn Akku Snap In ab ist?
Ra Ku - Contestar
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - Contestar
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 18
Ultimos 30 días: 76
Todo El Tiempo: 15,554
