Saltar al contenido principal
Kodak EasyShare LS743 Capacitor Replacement
Qué necesitas
  1. Kodak EasyShare LS743 Capacitor Replacement, Battery: paso 1, imagen 1 de 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Capacitor Replacement: paso 2, imagen 1 de 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Capacitor Replacement, Kodak EasyShare LS743 Camera Case Disassembly: paso 3, imagen 1 de 3 Kodak EasyShare LS743 Capacitor Replacement, Kodak EasyShare LS743 Camera Case Disassembly: paso 3, imagen 2 de 3 Kodak EasyShare LS743 Capacitor Replacement, Kodak EasyShare LS743 Camera Case Disassembly: paso 3, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Capacitor Replacement: paso 4, imagen 1 de 3 Kodak EasyShare LS743 Capacitor Replacement: paso 4, imagen 2 de 3 Kodak EasyShare LS743 Capacitor Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Capacitor Replacement: paso 5, imagen 1 de 2 Kodak EasyShare LS743 Capacitor Replacement: paso 5, imagen 2 de 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Capacitor Replacement, Capacitor: paso 6, imagen 1 de 3 Kodak EasyShare LS743 Capacitor Replacement, Capacitor: paso 6, imagen 2 de 3 Kodak EasyShare LS743 Capacitor Replacement, Capacitor: paso 6, imagen 3 de 3
    • The capacitor can store electricity even when the camera is off! Do not touch it until you have safely discharged it.
    • Connect the two capacitor wires briefly with a pair of metal tweezers to discharge the capacitor. You may see a small spark.
    • Remove eight screws using a Phillips #00 screwdriver.
    • Two (4.31 mm) screws are in the front of the camera.
    • Two (3.30 mm) screws are located in the bottom of the camera.
    • This causes the tripod mount on the bottom to become loose.
    • Four (3 x 3.33 mm and 1 x 4.34 mm) screws are in the back of the camera.
  7. Kodak EasyShare LS743 Capacitor Replacement: paso 7, imagen 1 de 1
    • Remove the tripod mount from the bottom of the camera and set it aside.
  8. Kodak EasyShare LS743 Capacitor Replacement: paso 8, imagen 1 de 1
    • Pull the black latch outward slightly to release the orange flex cable.
    • Carefully disconnect the orange flex cable.
  9. Kodak EasyShare LS743 Capacitor Replacement: paso 9, imagen 1 de 1
    • Soldering irons pose a burn risk if handled improperly.
    • Desolder the red and black wire and remove them.
  10. Kodak EasyShare LS743 Capacitor Replacement: paso 10, imagen 1 de 2 Kodak EasyShare LS743 Capacitor Replacement: paso 10, imagen 2 de 2
    • Hold the camera firmly and gently remove the capacitor (attached by adhesive) by wiggling it loose.
    • Desolder the pink and black wire and remove both of them.
Conclusión
Una persona más ha completado esta guía.
Elizabeth Loui
Miembro Desde 06/24/10
81 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-8, Johann Summer 2010 Miembro de Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,254
