Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The capacitor can store electricity even when the camera is off! Do not touch it until you have safely discharged it. Connect the two capacitor wires briefly with a pair of metal tweezers to discharge the capacitor.  You may see a small spark. Remove eight screws using a Phillips #00 screwdriver.
  • The capacitor can store electricity even when the camera is off! Do not touch it until you have safely discharged it.
  • Connect the two capacitor wires briefly with a pair of metal tweezers to discharge the capacitor. You may see a small spark.
  • Remove eight screws using a Phillips #00 screwdriver.
  • Two (4.31 mm) screws are in the front of the camera.
  • Two (3.30 mm) screws are located in the bottom of the camera.
  • This causes the tripod mount on the bottom to become loose.
  • Four (3 x 3.33 mm and 1 x 4.34 mm) screws are in the back of the camera.
Insertar traducción aquí
