Saltar al contenido principal
Kindle Voyage Wifi Antenna Replacement
Qué necesitas
  1. Kindle Voyage Wifi Antenna Replacement, Back Panel: paso 1, imagen 1 de 2 Kindle Voyage Wifi Antenna Replacement, Back Panel: paso 1, imagen 2 de 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Wifi Antenna Replacement: paso 2, imagen 1 de 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Wifi Antenna Replacement: paso 3, imagen 1 de 3 Kindle Voyage Wifi Antenna Replacement: paso 3, imagen 2 de 3 Kindle Voyage Wifi Antenna Replacement: paso 3, imagen 3 de 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Wifi Antenna Replacement: paso 4, imagen 1 de 2 Kindle Voyage Wifi Antenna Replacement: paso 4, imagen 2 de 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: paso 5, imagen 1 de 2 Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: paso 5, imagen 2 de 2
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
  6. Kindle Voyage Wifi Antenna Replacement: paso 6, imagen 1 de 3 Kindle Voyage Wifi Antenna Replacement: paso 6, imagen 2 de 3 Kindle Voyage Wifi Antenna Replacement: paso 6, imagen 3 de 3
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
Conclusión
Sean Yap
Miembro Desde 01/22/15
1,268 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 19-12, Maness Winter 2015 Miembro de Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Miembros
8 Guías creadas
Un comentario
Re Kindle Voyage Wifi Antenna Replacement guide: I cannot find the WiFi antenna bar on your website to purchase a replacement. Do you sell it?
carol cooper - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 1,934
