Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Using the tweezers, undo the attached clip. Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head. You should now be able to simply take the WiFi bar off of the device.
  • Using the tweezers, undo the attached clip.
  • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
  • You should now be able to simply take the WiFi bar off of the device.
Insertar traducción aquí
