Saltar al contenido principal
Kenmore 110 Series Washing Machine Water Pump Replacement
Qué necesitas
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: paso 1, imagen 1 de 1
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: paso 2, imagen 1 de 3 Kenmore 110 Series Washing Machine Water Pump Replacement: paso 2, imagen 2 de 3 Kenmore 110 Series Washing Machine Water Pump Replacement: paso 2, imagen 3 de 3
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
Conclusión
14 personas más completaron esta guía.
Robert Trout
Miembro Desde 09/26/12
1,234 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 15-43, Forte Fall 2012 Miembro de Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Miembros
11 Guías creadas
9 comentarios
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Contestar
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Contestar
My clothes are still really wet.
Tracy Schultz - Contestar
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 81
Ultimos 30 días: 376
Todo El Tiempo: 58,967
