Saltar al contenido principal
Inglés
Español
Traduciendo paso 2
Paso 2
Carefully remove both wire harnesses connected to the pump. Squeeze and pull back hose clamp. Twist drain hose off of pump.
  • Carefully remove both wire harnesses connected to the pump.
  • Squeeze and pull back hose clamp.
  • Twist drain hose off of pump.
  • Using a 1/4" socket wrench, remove the three mounting screws.
  • Pull the pump out of place.
  • Pulling the pump away takes a little force.
Insertar traducción aquí
