Saltar al contenido principal
JBL Charge Battery Replacement
Qué necesitas
  1. JBL Charge Battery Replacement, Disassembling JBL Charge Casing: paso 1, imagen 1 de 3 JBL Charge Battery Replacement, Disassembling JBL Charge Casing: paso 1, imagen 2 de 3 JBL Charge Battery Replacement, Disassembling JBL Charge Casing: paso 1, imagen 3 de 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Battery Replacement: paso 2, imagen 1 de 2 JBL Charge Battery Replacement: paso 2, imagen 2 de 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Battery Replacement: paso 3, imagen 1 de 2 JBL Charge Battery Replacement: paso 3, imagen 2 de 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Battery Replacement: paso 4, imagen 1 de 2 JBL Charge Battery Replacement: paso 4, imagen 2 de 2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Battery Replacement: paso 5, imagen 1 de 2 JBL Charge Battery Replacement: paso 5, imagen 2 de 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Battery Replacement: paso 6, imagen 1 de 2 JBL Charge Battery Replacement: paso 6, imagen 2 de 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Battery Replacement: paso 7, imagen 1 de 2 JBL Charge Battery Replacement: paso 7, imagen 2 de 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Battery Replacement, Battery: paso 8, imagen 1 de 1
    • Turn your attention to the back casing removed in Step 7.
  9. JBL Charge Battery Replacement: paso 9, imagen 1 de 1
    • Using a razor blade, remove the glue holding the battery cable in place.
    • Use multiple vertical cuts to remove pieces of the glue.
    • Be careful not to cut the battery cables.
  10. JBL Charge Battery Replacement: paso 10, imagen 1 de 1
    • Remove the foam surrounding the battery cable.
  11. JBL Charge Battery Replacement: paso 11, imagen 1 de 1
    • To remove the battery, pull the battery cable through the hole.
    • This entire white piece needs to be replaced (if replacing the aux/usb port).
Conclusión
37 personas más completaron esta guía.
Joe Durand
Miembro Desde 04/01/15
2,182 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-4, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G4
2 Miembros
18 Guías creadas
32 comentarios
How i replaced a new battery in myjbl reflect headphone bluetooth
Mohamad Lutfi - Contestar
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
Ifeanyi Anaetoh - Contestar
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose -
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Delton Eason Jr - Contestar
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
Joe Durand -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 26
Ultimos 7 días: 140
Ultimos 30 días: 602
Todo El Tiempo: 226,063
