Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 4
Use a nylon spudger to lift the battery out of the device. Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
  • Use a nylon spudger to lift the battery out of the device.
  • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
  • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
Insertar traducción aquí
