Saltar al contenido principal
HTC Vive Facerest Replacement
Qué necesitas
  1. HTC Vive Facerest Replacement, Unscrew the head strap mounts: paso 1, imagen 1 de 2 HTC Vive Facerest Replacement, Unscrew the head strap mounts: paso 1, imagen 2 de 2
    • Be sure to power down and disconnect your Vive before beginning.
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • For some devices, a T6 Torx driver may work better.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
  2. HTC Vive Facerest Replacement, Remove the head strap mounts: paso 2, imagen 1 de 3 HTC Vive Facerest Replacement, Remove the head strap mounts: paso 2, imagen 2 de 3 HTC Vive Facerest Replacement, Remove the head strap mounts: paso 2, imagen 3 de 3
    • Remove both head strap mounts.
  3. HTC Vive Facerest Replacement, Remove the facerest: paso 3, imagen 1 de 2 HTC Vive Facerest Replacement, Remove the facerest: paso 3, imagen 2 de 2
    • Slide the facerest straight away from the headset to remove it.
Conclusión
4 personas más completaron esta guía.
Adam O'Camb
Miembro Desde 04/11/15
196,335 Reputación
416 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 30
Todo El Tiempo: 2,149
