Introducción
Use this guide to replace the headstrap on an HTC Vive Cosmos. In this guide the headphones remain attached to the headstrap. The hinge is not removed in this guide.
Make sure that the Vive Cosmos is powered off and disconnected from power before beginning disassembly.
Qué necesitas
Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
Lift the audio connector straight up to unplug it.
Grasp one end of the front headstrap pad and pull it away from the headstrap to remove it.
Carefully lift the audio connector cable out of its slot in the front of the headstrap.
Use a T5 Torx drive to remove the ten 4.1 mm long screws securing the headstrap.
