Introducción
The keyboard is the most essential input device for computers. Keystrokes are sent to the CPU and decoded to allow users to interact with the computer. This guide provides a step by step procedure to replace the keyboard of your HP Pavilion x360 14-ba253cl. All of the keys of the keyboard are connected in this model, so to fix any number of keys you must remove the entire keyboard. You might have to replace the keyboard if the buttons or the touch-pad are unresponsive or in cases of liquid spills. For this procedure, you will need a screwdriver along with 6 mm and 4 mm screw bits, an opening pick, and a spudger. This is a very straightforward procedure that does not require expertise in electronics.
Qué necesitas
Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
Use the blue plastic tab on the ribbon cable to pull it out from the system board.
Remove the keyboard from the laptop.
Una persona más ha completado esta guía.
