Saltar al contenido principal
HP Pavilion x360 14-ba253cl Battery Replacement
Qué necesitas
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: paso 1, imagen 1 de 1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: paso 2, imagen 1 de 1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: paso 3, imagen 1 de 1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: paso 4, imagen 1 de 1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: paso 5, imagen 1 de 1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: paso 7, imagen 1 de 1
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
Conclusión
5 personas más completaron esta guía.
Un comentario
Thanks, it was useful
Oleg - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 34
Ultimos 30 días: 132
Todo El Tiempo: 8,114
