Introducción
Taking apart the scanner tray is a prerequisite guide for most other guides pertaining to the scanner.
Carefully wedge the flathead 3/32" screwdriver on the outer groove of the control panel faceplate.
  • Carefully wedge the flathead 3/32" screwdriver on the outer groove of the control panel faceplate.
  • Follow the perimeter of the groove with the flathead 3/32" screwdriver making sure to gently pry and lift upward until the control panel faceplate comes off.
  • Take your time prying off the control panel faceplate. If too much pressure is applied, the control panel faceplate can break.
Agregar Comentario
Once the control panel faceplate is off, look for the Lock/Unlock tab located underneath the off button.
  • Once the control panel faceplate is off, look for the Lock/Unlock tab located underneath the off button.
  • To unlock and release the control panel, insert the flathead 3/32" screwdriver into the tab and carefully push down. The control panel will then separate from the printer's base by sliding it downward a little.
Agregar Comentario
Underneath the control panel will be a flat grey ribbon cable. This cable is  attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
  • Underneath the control panel will be a flat grey ribbon cable. This cable is attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
  • Carefully disconnect both ends of the flat grey ribbon cable to release the control panel in its entirety.
    • Only pull from the connector portion of the cable, as pulling on the wires may damage them.
Agregar Comentario
Lift open the scanner lid and locate a black tab located at the center of the scanner bed.
  • Lift open the scanner lid and locate a black tab located at the center of the scanner bed.
  • Using your finger push (pull on some printers) the tab towards the scanner lid. This will release the scanner lid
Agregar Comentario
Once the scanner lid is removed use the Philips #1(Torx on some printers) Screwdriver to remove the screw. Once the scanner lid is removed use the Philips #1(Torx on some printers) Screwdriver to remove the screw.
  • Once the scanner lid is removed use the Philips #1(Torx on some printers) Screwdriver to remove the screw.
Agregar Comentario
Remove all four silver screws from the corners of the scanner glass cover with a T10 Torx Screwdriver. Organization is everything. Remember to have your iFixit Magnetic Work Mat next to you. It will help keep screws organized and in place.
  • Remove all four silver screws from the corners of the scanner glass cover with a T10 Torx Screwdriver.
  • Organization is everything. Remember to have your iFixit Magnetic Work Mat next to you. It will help keep screws organized and in place.
Agregar Comentario
Once you have removed the four torx screws, gently lift the scanner glass cover from the printer's base.
  • Once you have removed the four torx screws, gently lift the scanner glass cover from the printer's base.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Hilary Olsen
Miembro Desde 12/04/11
179 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-31, Maness Spring 2011 Miembro de Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 22
Todo El Tiempo: 6,515
