Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 3
Underneath the control panel will be a flat grey ribbon cable. This cable is  attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
  • Underneath the control panel will be a flat grey ribbon cable. This cable is attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
  • Carefully disconnect both ends of the flat grey ribbon cable to release the control panel in its entirety.
  • Only pull from the connector portion of the cable, as pulling on the wires may damage them.
Insertar traducción aquí
