Saltar al contenido principal
HP Envy TouchSmart 15 Wireless Adapter Replacement
Qué necesitas
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: paso 1, imagen 1 de 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: paso 3, imagen 1 de 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: paso 3, imagen 2 de 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: paso 4, imagen 1 de 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: paso 4, imagen 2 de 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: paso 4, imagen 3 de 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: paso 5, imagen 1 de 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: paso 5, imagen 2 de 2
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: paso 6, imagen 1 de 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: paso 6, imagen 2 de 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: paso 6, imagen 3 de 3
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
Conclusión
4 personas más completaron esta guía.
Robert Patterson
Miembro Desde 09/04/15
1,442 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 2-6, Sullivan Fall 2015 Miembro de USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Miembros
10 Guías creadas
Un comentario
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 3,115
