Introducción
How to remove the battery of a HP Elitebook x360 1030 G2 laptop. The images and information in this guide were taken from this computer's service manual.
Qué necesitas
Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
Disconnect the power from the computer by unplugging the power cord from the computer.
Disconnect all external devices from the computer.
Remove the five Torx-4 T4M2.0×7.4 shoulder screws that secure the bottom cover to the computer.
Use a spudger to separate the rear edge of the bottom cover and the keyboard/top cover.
Remove the bottom cover by sliding it up and back at an angle.
Disconnect the battery cable from the system board.
Remove the six Phillips PM2.0×5.3 screws that secure the battery to the keyboard/top cover.
Remove the battery.
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
