Saltar al contenido principal
HP EliteBook 850 G5 Battery Replacement
Qué necesitas
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover screws: paso 2, imagen 1 de 1
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
  2. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover: paso 3, imagen 1 de 1
    • Starting under the middle of the display, pry and lift the bottom cover off the computer. Consider using a spudger.
  3. HP EliteBook 850 G5 Battery Replacement, Disconnect the battery: paso 4, imagen 1 de 1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  4. HP EliteBook 850 G5 Battery Replacement, Remove the battery: paso 5, imagen 1 de 1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
Conclusión
To replace the battery & reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Max Kletskov
Miembro Desde 04/22/20
40,298 Reputación
16 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,182 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 64
Ultimos 30 días: 303
Todo El Tiempo: 5,815
