Saltar al contenido principal
HP EliteBook 830 G5 Battery Replacement
Qué necesitas
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer
    • Disconnect all external devices from the computer.
  1. HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: paso 2, imagen 1 de 2 HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: paso 2, imagen 2 de 2
    • Turn the computer upside down on a flat surface.
    • Loosen the five captive screws.
    • Loosen the two inset captive screws.
    • Starting under the display, insert a case removal tool and lift the bottom cover of the computer.
  2. HP EliteBook 830 G5 Battery Replacement, Remove the battery: paso 3, imagen 1 de 2 HP EliteBook 830 G5 Battery Replacement, Remove the battery: paso 3, imagen 2 de 2
    • Disconnect the battery cable from the system board.
    • Remove the five Torx T8 2.5×4.0 screws.
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
Conclusión
To replace the battery & reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Max Kletskov
Miembro Desde 04/22/20
40,298 Reputación
16 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,222 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 100
Todo El Tiempo: 2,161
