Saltar al contenido principal
HP EliteBook 745 G4 Battery Replacement
Qué necesitas
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: paso 2, imagen 1 de 1
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: paso 3, imagen 1 de 2 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: paso 3, imagen 2 de 2
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: paso 4, imagen 1 de 1
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: paso 5, imagen 1 de 1
    • Loosen the two captive screws and remove the battery from the computer
Conclusión
To replace the battery & reassemble your device, follow these instructions in reverse order.
3 personas más completaron esta guía.
Max Kletskov
Miembro Desde 04/22/20
40,307 Reputación
16 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,430 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 33
Todo El Tiempo: 1,188
