Saltar al contenido principal
HP Elite X2 1013 G3 Battery Replacement
Qué necesitas
  1. HP Elite X2 1013 G3 Battery Replacement, Screen: paso 1, imagen 1 de 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Battery Replacement: paso 2, imagen 1 de 2 HP Elite X2 1013 G3 Battery Replacement: paso 2, imagen 2 de 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Battery Replacement: paso 3, imagen 1 de 2 HP Elite X2 1013 G3 Battery Replacement: paso 3, imagen 2 de 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Battery Replacement: paso 4, imagen 1 de 2 HP Elite X2 1013 G3 Battery Replacement: paso 4, imagen 2 de 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Battery Replacement: paso 6, imagen 1 de 1
    • Lift the battery out of the housing.
Conclusión
Una persona más ha completado esta guía.
Asmita Sharma
Miembro Desde 04/18/19
186 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S9-G12, Maness Spring 2019 Miembro de Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 64
Todo El Tiempo: 2,477
