Saltar al contenido principal
GoPro Hero5 Black Battery Housing Replacement
Qué necesitas
  1. GoPro Hero5 Black Battery Housing Replacement, Battery: paso 1, imagen 1 de 3 GoPro Hero5 Black Battery Housing Replacement, Battery: paso 1, imagen 2 de 3 GoPro Hero5 Black Battery Housing Replacement, Battery: paso 1, imagen 3 de 3
    • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
  2. GoPro Hero5 Black Battery Housing Replacement: paso 2, imagen 1 de 3 GoPro Hero5 Black Battery Housing Replacement: paso 2, imagen 2 de 3 GoPro Hero5 Black Battery Housing Replacement: paso 2, imagen 3 de 3
    • Grab the plastic flap on the battery and pull the battery out.
  3. GoPro Hero5 Black Battery Housing Replacement, Back Housing: paso 3, imagen 1 de 2 GoPro Hero5 Black Battery Housing Replacement, Back Housing: paso 3, imagen 2 de 2
    • Pull and twist the lens cover right or left until it pops off.
    • The lens cover is secured tightly and might be difficult to twist off.
  4. GoPro Hero5 Black Battery Housing Replacement: paso 4, imagen 1 de 1
    • This step is not necessary but will make the process of removing the faceplate much easier.
    • Refer to the iOpener instructions for how to heat up and use the iOpener.
    • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
    • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
  5. GoPro Hero5 Black Battery Housing Replacement: paso 5, imagen 1 de 3 GoPro Hero5 Black Battery Housing Replacement: paso 5, imagen 2 de 3 GoPro Hero5 Black Battery Housing Replacement: paso 5, imagen 3 de 3
    • Starting with the edges, use the spudger to pry off the faceplate.
    • The faceplate is held down with adhesive and may take a while to get off.
  6. GoPro Hero5 Black Battery Housing Replacement: paso 6, imagen 1 de 2 GoPro Hero5 Black Battery Housing Replacement: paso 6, imagen 2 de 2
    • Remove the six T3 Torx screws.
  7. GoPro Hero5 Black Battery Housing Replacement: paso 7, imagen 1 de 3 GoPro Hero5 Black Battery Housing Replacement: paso 7, imagen 2 de 3 GoPro Hero5 Black Battery Housing Replacement: paso 7, imagen 3 de 3
    • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
    • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
  8. GoPro Hero5 Black Battery Housing Replacement: paso 8, imagen 1 de 3 GoPro Hero5 Black Battery Housing Replacement: paso 8, imagen 2 de 3 GoPro Hero5 Black Battery Housing Replacement: paso 8, imagen 3 de 3
    • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
  9. GoPro Hero5 Black Battery Housing Replacement: paso 9, imagen 1 de 2 GoPro Hero5 Black Battery Housing Replacement: paso 9, imagen 2 de 2
    • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
  10. GoPro Hero5 Black Battery Housing Replacement, Battery Housing: paso 10, imagen 1 de 1
    • Remove the 3mm #000 Phillips screw.
    • Remove the 2mm #000 Phillips screw.
  11. GoPro Hero5 Black Battery Housing Replacement: paso 11, imagen 1 de 1
    • Use the tweezers to grasp the housing firmly and pull it away from the three ribbon cables.
    • Pull the battery housing until the half circle grooves on the back housing match up with the grooves on the battery housing.
    • After the screws have been removed from the inside, the battery housing is only held down by adhesive.
  12. GoPro Hero5 Black Battery Housing Replacement: paso 12, imagen 1 de 2 GoPro Hero5 Black Battery Housing Replacement: paso 12, imagen 2 de 2
    • Make sure the half circle grooves match up. Otherwise the battery housing will not be able to be pulled out.
    • With your fingers, push from the inside of the battery compartment and pull the battery housing out from the back housing.
Conclusión
10 personas más completaron esta guía.
Equipo
Cal Poly, Team 18-6, Forte Fall 2016 Miembro de Cal Poly, Team 18-6, Forte Fall 2016
CPSU-FORTE-F16S18G6
4 Miembros
22 Guías creadas
Un comentario
Is there any glue to use to make the case waterproof again?
Dominik Lisiakiewicz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 80
Todo El Tiempo: 12,985
