Saltar al contenido principal
GoPro Hero3+ Silver Edition Image Sensor Replacement
Qué necesitas
  1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: paso 1, imagen 1 de 2 GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: paso 1, imagen 2 de 2
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero3+ Silver Edition Image Sensor Replacement: paso 2, imagen 1 de 1
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero3+ Silver Edition Image Sensor Replacement, Front Panel: paso 3, imagen 1 de 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero3+ Silver Edition Image Sensor Replacement: paso 4, imagen 1 de 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: paso 5, imagen 1 de 3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: paso 5, imagen 2 de 3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: paso 5, imagen 3 de 3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  6. GoPro Hero3+ Silver Edition Image Sensor Replacement: paso 6, imagen 1 de 2 GoPro Hero3+ Silver Edition Image Sensor Replacement: paso 6, imagen 2 de 2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero3+ Silver Edition Image Sensor Replacement: paso 7, imagen 1 de 1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero3+ Silver Edition Image Sensor Replacement: paso 8, imagen 1 de 2 GoPro Hero3+ Silver Edition Image Sensor Replacement: paso 8, imagen 2 de 2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
Conclusión
4 personas más completaron esta guía.
Patrick Cook
Miembro Desde 10/01/15
687 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Maness Fall 2015 Miembro de Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 9
Todo El Tiempo: 753
