Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver. Gently remove the motherboard by using a plastic opening tool to pry it out of the housing. Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
  • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
  • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
Insertar traducción aquí
