Saltar al contenido principal
Dell XPS 15 9560 Battery Replacement
Qué necesitas
  1. Dell XPS 15 9560 Battery  Replacement, Back Panel: paso 1, imagen 1 de 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Battery  Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Battery  Replacement: paso 3, imagen 1 de 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Battery  Replacement, Battery: paso 4, imagen 1 de 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Battery  Replacement: paso 5, imagen 1 de 1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Battery  Replacement: paso 6, imagen 1 de 1
    • Remove the battery.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 personas más completaron esta guía.
Jada Houser
Miembro Desde 09/28/21
790 Reputación
7 Guías creadas
Equipo
Clemson, Team 4-5, Hunter Fall 2021 Miembro de Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Miembros
15 Guías creadas
Un comentario
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 62
Ultimos 30 días: 304
Todo El Tiempo: 9,071
