Saltar al contenido principal
Dell XPS 13 9370 Battery Replacement
Qué necesitas
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: paso 2, imagen 1 de 1
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: paso 3, imagen 1 de 2 Dell XPS 13 9370 Battery Replacement, Remove the base cover: paso 3, imagen 2 de 2
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: paso 4, imagen 1 de 1
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: paso 5, imagen 1 de 1
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
Conclusión
To replace the battery & reassemble your device, follow these instructions in reverse order.
23 personas más completaron esta guía.
Max Kletskov
Miembro Desde 04/22/20
40,298 Reputación
16 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,161 Guías creadas
8 comentarios
Is the battery an original dell battery?
mnyousafva - Contestar
Why doesn’t it say what tools are needed?
Noah Guirguis - Contestar
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - Contestar
Instructions were perfect, thanks for the great guide!
surfdaworld - Contestar
Boom, in a good way! I fixed it!
Chris Cox - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 17
Ultimos 7 días: 95
Ultimos 30 días: 508
Todo El Tiempo: 15,260
