Saltar al contenido principal
Dell Inspiron 7000 2 in 1 Battery Replacement
Qué necesitas
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 2, imagen 1 de 1
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 3, imagen 1 de 3 Dell Inspiron 7000 2 in 1 Battery Replacement: paso 3, imagen 2 de 3 Dell Inspiron 7000 2 in 1 Battery Replacement: paso 3, imagen 3 de 3
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 4, imagen 1 de 1
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 5, imagen 1 de 1
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 6, imagen 1 de 1
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 7, imagen 1 de 1
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 8, imagen 1 de 1
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 9, imagen 1 de 1
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: paso 10, imagen 1 de 1
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
Linea de Meta
3 personas más completaron esta guía.
Neelay Patel
Miembro Desde 09/17/21
255 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 50
Ultimos 30 días: 190
Todo El Tiempo: 5,584
