Saltar al contenido principal
Dell Inspiron 15-7567 Battery Replacement
Qué necesitas
  1. Dell Inspiron 15-7567 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Battery Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-7567 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-7567 Battery Replacement: paso 4, imagen 2 de 2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Battery Replacement: paso 5, imagen 1 de 2 Dell Inspiron 15-7567 Battery Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Battery Replacement: paso 6, imagen 1 de 1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 32
Todo El Tiempo: 6,689
