Saltar al contenido principal
Dell Inspiron 15 7560 Fan Replacement
Qué necesitas
  1. Dell Inspiron 15 7560 Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Power off the laptop.
    • Place the laptop with the bottom facing upwards.
    • Remove eight 5 mm screws from the bottom of the laptop.
    • Loosen the three captive screws.
    • Use an iFixit opening tool to pry the bottom cover away from the laptop.
  2. Dell Inspiron 15 7560 Fan Replacement: paso 2, imagen 1 de 1
    • Remove the two screws from the fan.
  3. Dell Inspiron 15 7560 Fan Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15 7560 Fan Replacement: paso 3, imagen 2 de 2
    • Remove the black insulating tape from the fan connector.
    • Pinch the sides of the white fan connector with your thumb and index fingernail and pull it out of its socket.
    • Remove the fan from the laptop.
    • Save the insulating tape for reinstallation.
  4. Dell Inspiron 15 7560 Fan Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15 7560 Fan Replacement: paso 4, imagen 2 de 2
    • Place the new fan in the laptop.
    • Plug the cable connector into its socket on the motherboard.
    • Replace the two screws around the fan.
  5. Dell Inspiron 15 7560 Fan Replacement: paso 5, imagen 1 de 1
    • Before replacing the bottom cover, start the computer to check if the cooling fan is installed successfully.
  6. Dell Inspiron 15 7560 Fan Replacement: paso 6, imagen 1 de 1
    • Power down the computer.
    • Reassemble the bottom cover.
Linea de Meta
Kristen Gismondi
Miembro Desde 11/12/14
82,335 Reputación
200 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,303 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 675
