Saltar al contenido principal
Dell Inspiron 13-7353 Battery Replacement
Qué necesitas
  1. Dell Inspiron 13-7353 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Battery Replacement: paso 2, imagen 1 de 1
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the battery up and out of the computer.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 991
