Saltar al contenido principal
Dell Inspiron 13-7352 System Board Replacement
Qué necesitas
  1. Dell Inspiron 13-7352 System Board Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 13-7352 System Board Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 13-7352 System Board Replacement, Battery: paso 1, imagen 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 System Board Replacement: paso 2, imagen 1 de 2 Dell Inspiron 13-7352 System Board Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 System Board Replacement: paso 3, imagen 1 de 1
    • Gently remove the battery from the rest of the device.
  4. Aviso: los pasos 4-5 provienen de una guía que está marcada como "En progreso".
    Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): paso 4, imagen 1 de 3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): paso 4, imagen 2 de 3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): paso 4, imagen 3 de 3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 System Board Replacement: paso 5, imagen 1 de 1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
  6. Dell Inspiron 13-7352 System Board Replacement, System Board: paso 6, imagen 1 de 3 Dell Inspiron 13-7352 System Board Replacement, System Board: paso 6, imagen 2 de 3 Dell Inspiron 13-7352 System Board Replacement, System Board: paso 6, imagen 3 de 3
    • Remove cord that runs from system board to the I/O board.
    • Remove connecting wire that runs from fan to system board.
  7. Dell Inspiron 13-7352 System Board Replacement: paso 7, imagen 1 de 1
    • Remove the 3mm and 4mm screws using the Phillips #0 head for both that hold down the fan
  8. Dell Inspiron 13-7352 System Board Replacement: paso 8, imagen 1 de 1
    • Lift the fan from the system board by using your thumb and index or middle finger to gently pull away from the rest of the device.
  9. Dell Inspiron 13-7352 System Board Replacement: paso 9, imagen 1 de 3 Dell Inspiron 13-7352 System Board Replacement: paso 9, imagen 2 de 3 Dell Inspiron 13-7352 System Board Replacement: paso 9, imagen 3 de 3
    • Remove the three 4mm screws with the Phillips #0 holding down the heat sink.
    • Remove the two 4mm screws with the Phillips #0 holding down the metal bracket.
    • Unscrew the single 3mm screw using the Phillips #0 head securing the system board.
  10. Dell Inspiron 13-7352 System Board Replacement: paso 10, imagen 1 de 2 Dell Inspiron 13-7352 System Board Replacement: paso 10, imagen 2 de 2
    • Remove the wire connections attached to the system board.
    • Remove the tape wires from the system board.
  11. Dell Inspiron 13-7352 System Board Replacement: paso 11, imagen 1 de 1
    • Carefully remove the system board from the base by grasping with thumb and index or middle finger and pulling away from the rest of the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 13
Todo El Tiempo: 1,819
