Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
Qué necesitas
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: paso 1, imagen 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: paso 2, imagen 1 de 2 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: paso 3, imagen 1 de 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): paso 4, imagen 1 de 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): paso 4, imagen 2 de 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): paso 4, imagen 3 de 3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: paso 5, imagen 1 de 1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
Conclusión
4 personas más completaron esta guía.
Chase Sparkman
Miembro Desde 09/30/15
512 Reputación
2 Guías creadas
Equipo
4Guía Comentarios
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - Contestar Compartir
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - Contestar Compartir
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - Contestar Compartir
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 38
Todo El Tiempo: 3,600
