Introducción
Need to get inside your Blackberry Storm to fix it? Or just want to salvage parts? This is an easy to follow guide to do it!
Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
Agregar Comentario
Turn your Storm where the battery door is facing up. Remove the battery door. Remove the battery.
  • Turn your Storm where the battery door is facing up.
  • Remove the battery door.
  • Remove the battery.
Agregar Comentario
Remove the two hex screws as shown by the SIM card slot.
  • Remove the two hex screws as shown by the SIM card slot.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool. Remove the two hex screws underneath it.
  • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
  • Remove the two hex screws underneath it.
Agregar Comentario
Turn the phone over and remove the plastic cover under the buttons as shown. Remove the 2 screws underneath. Remove the 2 screws underneath.
  • Turn the phone over and remove the plastic cover under the buttons as shown.
  • Remove the 2 screws underneath.
Agregar Comentario
Go around your device with the plastic pry tool, there a 3 clips on each side of the housing. There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself. There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
  • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
Agregar Comentario
You now have 3 pieces. The rear, mid , & front housing.
  • You now have 3 pieces. The rear, mid , & front housing.
Agregar Comentario
To remove the screen gently pry up this ribbon cable with a pry tool. To remove the screen gently pry up this ribbon cable with a pry tool.
  • To remove the screen gently pry up this ribbon cable with a pry tool.
Agregar Comentario
To remove the main board from the mid housing disconnect the ribbon cable as pictured. Now follow in reverse order for reassembly! Now follow in reverse order for reassembly!
  • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
  • Now follow in reverse order for reassembly!
Agregar Comentario
Conclusión
6 personas más completaron esta guía.
Josh Forester
Miembro Desde 28/11/10
2,303 Reputación
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 9,350
