Saltar al contenido principal
Alienware M15x GPU Replacement
Qué necesitas
  1. Alienware M15x GPU Replacement, GPU: paso 1, imagen 1 de 1
    • Turn the laptop over so that the bottom is facing upward.
  2. Alienware M15x GPU Replacement: paso 2, imagen 1 de 1
    • Release the battery latch and flip the battery out.
  3. Alienware M15x GPU Replacement: paso 3, imagen 1 de 2 Alienware M15x GPU Replacement: paso 3, imagen 2 de 2
    • Remove the two 4mm screws using a Phillips #1 screwdriver.
    • Remove the compartment door by sliding it away from the battery.
  4. Alienware M15x GPU Replacement: paso 4, imagen 1 de 1
    • Remove the four 4mm screws with the Phillips #1 screwdriver.
  5. Alienware M15x GPU Replacement: paso 5, imagen 1 de 1
    • Position the laptop vertically so that the hinge is facing up and the laptop is slightly open toward the ground
    • The laptop position should resemble an upside-down V shape.
    • Locate the panel and pry open using a plastic opening tool.
  6. Alienware M15x GPU Replacement: paso 6, imagen 1 de 3 Alienware M15x GPU Replacement: paso 6, imagen 2 de 3 Alienware M15x GPU Replacement: paso 6, imagen 3 de 3
    • Position the laptop normally, with the bottom on the ground and the screen flipped up towards you.
    • Lift the power button panel using the plastic opening tool.
    • Disconnect the ribbon cable by using tweezers to unclip the two small black clips. Remove power button panel.
  7. Alienware M15x GPU Replacement: paso 7, imagen 1 de 1
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
  8. Alienware M15x GPU Replacement: paso 8, imagen 1 de 2 Alienware M15x GPU Replacement: paso 8, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the 4mm screw from the exhaust port cover.
    • Remove the exhaust port cover entirely.
  9. Alienware M15x GPU Replacement: paso 9, imagen 1 de 3 Alienware M15x GPU Replacement: paso 9, imagen 2 de 3 Alienware M15x GPU Replacement: paso 9, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the two 3mm screws holding the fan in place, then unclip the electrical connection using tweezers.
  10. Alienware M15x GPU Replacement: paso 10, imagen 1 de 1
    • Remove the heat sink by loosening the 4 screws with a Phillips #0 screwdriver.
  11. Alienware M15x GPU Replacement: paso 11, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the two screws.
    • Remove the GPU from the laptop.
    • When replacing the GPU, it is important to reapply thermal paste in a small line along the length of the chip.
Conclusión
Tomas Kronmark
Miembro Desde 01/22/18
193 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G3, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 1,626
