Saltar al contenido principal
Inglés
Español
Paso 6
Position the laptop normally, with the bottom on the ground and the screen flipped up towards you. Use the same plastic opening tool to lift the power button panel. Once lifted, unclip the power button using tweezers on the two black clips. Remove the panel completely. Position the laptop normally, with the bottom on the ground and the screen flipped up towards you. Use the same plastic opening tool to lift the power button panel. Once lifted, unclip the power button using tweezers on the two black clips. Remove the panel completely. Position the laptop normally, with the bottom on the ground and the screen flipped up towards you. Use the same plastic opening tool to lift the power button panel. Once lifted, unclip the power button using tweezers on the two black clips. Remove the panel completely.
  • Position the laptop normally, with the bottom on the ground and the screen flipped up towards you. Use the same plastic opening tool to lift the power button panel. Once lifted, unclip the power button using tweezers on the two black clips. Remove the panel completely.
Insertar traducción aquí
