Saltar al contenido principal
Acer Aspire E1-532-2616 Battery Replacement
Qué necesitas
  1. Acer Aspire E1-532-2616 Battery Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire E1-532-2616 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Insert a small, skinny tool, such as a spudger, into the battery release latch.
  2. Acer Aspire E1-532-2616 Battery Replacement: paso 2, imagen 1 de 2 Acer Aspire E1-532-2616 Battery Replacement: paso 2, imagen 2 de 2
    • Slide the latch into the unlock position and pull the battery away from the laptop.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 1,519
