Saltar al contenido principal
ACER Aspire V5-571P-6609 Battery Replacement
Qué necesitas
  1. ACER Aspire V5-571P-6609 Battery Replacement, Battery Replacement: paso 1, imagen 1 de 1
    • Place the laptop facing down and find the slider close to the battery.
    • Use a screwdriver or other pointed tool to slide it to the right.
  2. ACER Aspire V5-571P-6609 Battery Replacement: paso 2, imagen 1 de 1
    • While keeping the slider pushed to the right, use your other hand to pull the battery out from the right side to the left until it completely comes out.
  3. ACER Aspire V5-571P-6609 Battery Replacement: paso 3, imagen 1 de 1
    • Install the new battery with the little tabs facing the laptop. Although keeping the slider pushed to the right when installing the new battery is recommended, it is not necessary; the battery can be inserted until it clicks in place.
Conclusión
No Reassembly Required
Mauricio O.
Miembro Desde 08/25/22
97 Reputación
1 Guía escrita
Equipo
Gateway, Team 1-1, Pee Fall 2022 Miembro de Gateway, Team 1-1, Pee Fall 2022
GCC-PEE-F22S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 191
