Saltar al contenido principal
OBSOLETE - How to Remove a stuck game from an Xbox 360
Qué necesitas
  1. OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: paso 1, imagen 1 de 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: paso 1, imagen 2 de 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: paso 1, imagen 3 de 3
    • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
  2. OBSOLETE - How to Remove a stuck game from an Xbox 360, Find the emergency eject hole: paso 2, imagen 1 de 1
    • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
  3. OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: paso 3, imagen 1 de 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: paso 3, imagen 2 de 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: paso 3, imagen 3 de 3
    • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
    • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
Conclusión
19 personas más completaron esta guía.
Nick
Miembro Desde 11/10/09
88,911 Reputación
49 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,541 Guías creadas
2 comentarios
will this work for elite 250 gug
duangphetv - Contestar
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 28
Todo El Tiempo: 31,425
