Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 7
Insert the edge of an iPod opening tool under the steel mid plate near the bottom left corner of the Touch. Pry upward to separate the plate from the adhesive securing it to the plastic inner case.
  • Insert the edge of an iPod opening tool under the steel mid plate near the bottom left corner of the Touch.
  • Pry upward to separate the plate from the adhesive securing it to the plastic inner case.
  • If the plate is still attached to the logic board re-warm the area to loosen the adhesive, then separate the plate from the logic board using the opening tool
  • Use extreme care, the speaker is under the area shown in photo. It is connected with very thin and short wires.
  • There is a very thin ribbon cable here that connects the volume and power buttons to the logic board. Try to work around this area like shown so not to rip the cable. Be sure to hold down this cable when lifting the plate. It could stick to the plate due to residual glue. It is extremely fragile.
  • This cable will tear very easily if you are not careful.
  • There is also adhesive under the area shown in red.
Insertar traducción aquí
