Saltar al contenido principal
Retina MacBook 2016 Opening Lower Case Assembly
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 25 guías que incluyen este paso.
Inglés
Holandés
Paso 11
Retina MacBook 2016 Opening Lower Case Assembly: paso 0, imagen 1 de 3 Retina MacBook 2016 Opening Lower Case Assembly: paso 0, imagen 2 de 3 Retina MacBook 2016 Opening Lower Case Assembly: paso 0, imagen 3 de 3
  • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
  • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
  • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
  • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
Insertar traducción aquí
