Saltar al contenido principal
Retina MacBook 2016 Opening Lower Case Assembly
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 25 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Retina MacBook 2016 Opening Lower Case Assembly, Unfasten the lower case: paso 0, imagen 1 de 1
  • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
  • Remove the following eight screws securing the lower case:
  • Two 1.8 mm P5 Pentalobe screws
  • Four 2.9 mm P5 Pentalobe screws
  • Two 6.1 mm P5 Pentalobe screws
  • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
  • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
Insertar traducción aquí
