Saltar al contenido principal
Ionic Breeze Disassembly
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Paso 4
Ionic Breeze Disassembly, Desolder Power Cable: paso 0, imagen 1 de 3 Ionic Breeze Disassembly, Desolder Power Cable: paso 0, imagen 2 de 3 Ionic Breeze Disassembly, Desolder Power Cable: paso 0, imagen 3 de 3
  • Photos depict where to desolder the power cables connection points. Remove any hot glue that may be holding down the cables. These devices are a little seasoned so the glue should not be hard to remove by hand.
  • I found it easiest to use the base to prop up the body, the half of the housing that the electronics typically reside in, in order to get a good angle at removing the solder. I'm sure it can be done on its side but lets work smarter, not harder here.
  • Remember to pull the ground cable completely through the PCB. We will re-thread it back through during the reassembly process.
  • Remember, the base is not attached at this point. Don't knock the Ionic Breeze over while it's in an upright position with it's internal components exposed.
Insertar traducción aquí
