Saltar al contenido principal
Dell Inspiron 13-7352 DC POWER JACK HARNESS Replacement
Inglés
Español
Traduciendo paso 1
Paso 1
Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: paso 0, imagen 1 de 3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: paso 0, imagen 2 de 3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: paso 0, imagen 3 de 3
Back Panel Removal
  • Before disassembling your laptop, be sure it is powered off.
  • Remove the ten 7.5mm screws that secure the back panel with the Phillips #0 head
  • Use the plastic opening tool to remove the back panel. Start at the back corner and work across. The front edge of the laptop panel hinges and pivots upward after the back edge and the side edges are separated from the casing.
Insertar traducción aquí
