Saltar al contenido principal
Reemplazo de Cable Flex de la Antena del iPhone 6
Inglés
Español
Traduciendo paso 1
Paso 1
iPhone 6 Antenna Flex Cable Replacement: paso 0, imagen 1 de 2 iPhone 6 Antenna Flex Cable Replacement: paso 0, imagen 2 de 2
  • Flip the logic board over to expose the antenna on the back side.
  • Disconnect the four coaxial connectors from the logic board and remove the antenna cable from the logic board.
  • Be careful not to touch any metal to metal contact points with your bare fingers—use tweezers or gloves. Finger oils may disrupt conductivity. If you do touch any of these components, clean them with a degreaser like windex or isopropyl alcohol before reassembly.
Da la vuelta a la placa lógica para exponer la antena en la parte posterior.
Desconecte los cuatro conectores coaxiales de la placa lógica y retire el cable de la antena de la placa lógica. Tenga cuidado de no tocar ningún punto de contacto de metal con metal con los dedos desnudos: use pinzas o guantes. Los aceites de los dedos pueden alterar la conductividad.
Si toca alguno de estos componentes, límpielos con un desengrasante como windex o alcohol isopropílico antes de volver a armarlos.
[* black] Flip the logic board over to expose the antenna on the back side.
[* black] Disconnect the four coaxial connectors from the logic board and remove the antenna cable from the logic board.
-[* icon_note] Be careful not to touch any metal to metal contact points with your bare fingers—use tweezers or gloves. Finger oils may disrupt conductivity. If you do touch any of these components, clean them with a degreaser like windex or isopropyl alcohol before reassembly.
+[* icon_note] Be careful not to touch any metal to metal contact points with your bare fingers—use [product|IF145-020|tweezers] or gloves. Finger oils may disrupt conductivity. If you do touch any of these components, clean them with a degreaser like windex or isopropyl alcohol before reassembly.
