Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 23 guías que incluyan este paso.
Inglés
Español
Paso 9
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Removing the front panel assembly cable bracket screws
  • Remove the following five Phillips screws securing the front panel assembly cable bracket:
  • Three 1.2 mm screws
  • One 1.7 mm screw
  • One 3.1 mm screw
  • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
Quita los siguientes cinco tornillos Phillips del soporte de cable del ensamblaje del panel frontal:
Tres tornillos de 1.2 mm
Un tornillo de 1.7 mm
Un tornillo de 3.1 mm
La colocación incorrecta de estos tornillos durante el resamblado, puede causar daños permanentes a la placa lógica del iPhone
[title] Removing the front panel assembly cable bracket screws
[* black] Remove the following five Phillips screws securing the front panel assembly cable bracket:
[* red] Three 1.2 mm screws
[* orange] One 1.7 mm screw
[* yellow] One 3.1 mm screw
[* icon_caution] Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
