Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 23 guías que incluyan este paso.
Inglés
Español
Paso 6
Remove the following Phillips screws from the battery connector bracket:
Removing the battery connector bracket screws
  • Remove the following Phillips screws from the battery connector bracket:
  • One 2.2 mm screw
  • One 3.2 mm screw
  • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
Quita los siguente tornillos del soporte del conector de batería:
Un tornillo Phillips #00 de 2.2 mm
Un tornillo Phillips #00 de 3.2 mm
Durante la reparación, guarda por separado cada tipo de tornillo, y asegúrate de que vuelves a ponerlos exactamente en el mismo lugar que les corresponde, para evitar dañar tu teléfono
[*title] Removing the battery connector bracket screws
black] Remove the following Phillips #00 screws from the battery connector bracket:
[* red] One 2.2 mm screw
[* orange] One 3.2 mm screw
[* icon_note] During your repair, [product|IF145-167-4|keep track of each screw|new_window=true] and make sure it goes back exactly where it came from to avoid damaging your phone.
