Saltar al contenido principal
MacBook Unibody Model A1278 Front Display Glass Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 8
MacBook Unibody Model A1278 Front Display Glass Replacement: paso 0, imagen 1 de 2 MacBook Unibody Model A1278 Front Display Glass Replacement: paso 0, imagen 2 de 2
  • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
  • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
  • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on. It is recommended to use a silicon roller and sticky sheets to clean well.
Insertar traducción aquí
