Saltar al contenido principal
Reemplazo de ensamblaje de placa madre del LG V20
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
LG V20 MB Assembly Replacement: paso 0, imagen 1 de 1
  • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
  • The second rear camera will come out with the motherboard since it is connected on the other side.
  • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
Usa el extremo plano de un spudger para desconectar el cable flexible de la cámara izquierda trasera.
La segunda cámara trasera saldrá con la placa madre ya que está conectada en el otro lado.
Puedes dejar la cámara frontal en su lugar siempre y cuando tengas cuidado al remover el ensamblaje de la placa madre. Sin embargo, si no estás seguro, remuévela con cuidado con un par de pinzas.
[* black] Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
[* black] The second rear camera will come out with the motherboard since it is connected on the other side.
-[* black] You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
+[* black] You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of [product|IF145-020|tweezers].
