Saltar al contenido principal
Google Pixel Display Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Holandés
Paso 4
Google Pixel Display Replacement: paso 0, imagen 1 de 3 Google Pixel Display Replacement: paso 0, imagen 2 de 3 Google Pixel Display Replacement: paso 0, imagen 3 de 3
  • Insert an opening pick or a playing card into the gap between the chassis and the display assembly.
  • Begin to slide the opening pick around the edge of the display, cutting through the adhesive that secures it.
  • Do not try to lift or pry the screen off with the pick. Simply slide it around to detach the adhesive.
  • The display panel is extremely fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
Insertar traducción aquí
