Saltar al contenido principal
Asus ROG Strix GL702VM-BHI7N09 Back Panel Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 10 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Asus ROG Strix GL702VM-BHI7N09 Back Panel Replacement: paso 0, imagen 1 de 3 Asus ROG Strix GL702VM-BHI7N09 Back Panel Replacement: paso 0, imagen 2 de 3 Asus ROG Strix GL702VM-BHI7N09 Back Panel Replacement: paso 0, imagen 3 de 3
  • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
  • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
  • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
  • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
  • Once you have broken all the seals, carefully lift the panel off.
Insertar traducción aquí
